wd 45 genterator system
bill 1946
08-21-2004 07:51:00
need help guys. my genterator and cut out relay is a delco system. first off i removed the two wires from the relay to the genterator off.now im not sure if i hooked them up rt. the relay has 3 termals one say batt the orther says genterator the last one i cant read.the one that says battery i know i have that rt. now the genterator has markingings of A and F. SO from the relay to genterator the one that says gent goes to termal A OR F THANK YOU BILL
Duey (IA)
08-22-2004 20:50:02
 Re: wd 45 genterator system in reply to bill 1946, 08-21-2004 07:51:00
third party image
Here is a wiring diagram or go to parts and pieces in the column on the left of the screen to view.
DanD.
08-21-2004 11:39:47
The wire from the A on the generator goes to the "GEN" terminal on the cutout. The wire from the F terminal on the generator goes to the light switch resistor. I have never seen a Delco cutout with three terminals. They only have two. Are you sure it"s a cutout and not a voltage regulator?
bill 1946
08-22-2004 07:19:46
 Re: wd 45 genterator system in reply to DanD., 08-21-2004 11:39:47
Dan and Steve thank you for the help. it is a voltage regolator and not a cutout. again thank you guys i got my awnser.
steve(ill)
08-22-2004 06:01:45
a cutout has 2 wires, G and F because there is only one coil inside the box. a voltage regulator has 3 or 4 wires, G and F and a Battery line since it has 3 coils inside. the regulator does not need the light switch, the resistor on the light switch is replaced by one of the relays inside the regulator. ----- ----B is battery, from the ampmeter. G is the Armature (A) terminal on the generator. F is Field or ground wire. you dont need a light switch. If you ground the F terminal and reasure the voltage between the A and F terminals on the generator, you can check its operation. the regulator is there to adjust the voltage and current output. make sure the F is grounded to a clen unpainted bolt., just like the battery ground terminal
Steve(sk)
08-23-2004 11:49:58
 Re: wd 45 genterator system in reply to steve(ill), 08-22-2004 06:01:45
Was happy to see diagram that was posted in this thread. I am getting a negative charge indicated on my ammeter and am wondering how to check ehat the problem is and fix it. Would greatly appreciate advice.
steve(ill)
08-23-2004 15:07:58
 Re: wd 45 genterator system in reply to Steve(sk), 08-23-2004 11:49:58
amp meter running backward might mean the wires are just reversed. is it actually charging or is it discharging? ground the F terminal on the gnerator, connect the A terminal to the ampmeter then to battery. it should read zero, then go up and charge several amps after startup. if it is doing this, but the wrong way, you probalby have the wires switched. turn on lights with the motor off, amp meter should discharge??
