Voltage Regulator Wiring Diagram
TAD
08-26-2004 17:39:34
Could someone help me by posting or emailing a wiring diagram for a C with a voltage regulator. I want to replace the cut-out with a voltage regulator and replace the 3 position light switch with just an on/off light switch. I am not sure how to do it, any help would be great! Thanks Tim
TAD
08-29-2004 18:49:20
 Re: Voltage Regulator Wiring Diagram in reply to TAD, 08-26-2004 17:39:34
Thanks guys!
Tim
Duey (IA)
08-29-2004 17:34:12
third party image
xxx
steve(ill)
08-27-2004 17:48:54
the voltage regulator will have 3 terminals, "B", "G", and "F" --- the generator has two terminals "A" and "F". A is armature or generator. F is field. B is battery.---- you connect the G on reg to A on genertor. F goes to F. B goes to the ampmeter one terminal. other side of the ampmeter goes to negative terminal on the baattery. "F" on the regulator is field or ground. the case will need to be grounded or bolted to clean unpainted metal.----- ----- - last thing to know is you have a "positive ground" system so you need a "positive ground " regulator. If you want a negative ground, like all new cars and truck then get a neg ground regulator and reverse the terminals on the battery.--- send me e-mail if needed spotter@frontiernet.net
Dave Grubb
08-27-2004 12:16:07
See my reply to a posting 4 listings down and go to the link I gave. I think the answer you need will be on Dueys site.
