I purchased a M-H 30 a couple of days ago. It started right up and ran great when I test drove it, with everything working well, minus minimal brakes and a broken brake return spring, which I didn't consider to be a problem. I can repair the brakes once I've become more used to the tractor and i have the spring ordered for it.
I drove it around my land a bit (testing to see how muddy it was and what wasn't frozen what was) then parked it in my shed after hauling it back to my house,. When I went to start it about 6 hours later to show my wife, I couldn't get it started.
It turned over fine, except I inadvertently flooded it and it didn't start. While trying to start it, the battery went dead.
I thought the carb float was stuck, so I drained the carb and noticed some discolored gas/junk from the bowl. I looked in the gas tank (which I had not done after hauling and noticed that there was debris--like bits of plastic or something in the bottom. So I drained the fuel line and cleaned it thinking there was maybe something in it too. I have good fuel flow to the carb. I will take the tank off and clean it once spring gets here and its warmer.
The carb had minimal fuel flow out of the drain flow. This made me think the float valve was stuck.
I did not take the carb off, I just sprayed carb cleaner inside of the gas inlet and the air intake and the bowl, really to get an idea of just how dirty/bad things were inside it. There was some dark murkey debris that came out, but everything appeared to flow freely. I have ordered a carb kit, but it wont be here for a few more days.
I charged the battery, put it back in two days later to see if I could get it started with the carb as it is, and it wouldn't turn over. It sort of half turned one time, then stopped. I thought the battery was just bad --its a 2 year battery that was 3 years old and its cold (below freezing) in my shed now.
I got a new battery today (4 days later) exactly like the one in it and hooked it up, but again everything is dead. I will start testing wires tomorrow to make sure current is going where it should be.
I tried to jump start it from the starter with my truck, it'll jerk, but then not turn over. I do not have a hand crank for this tractor. I assuming that i'm going to have to put it in gear and try to roll it and make sure the motor is not frozen now.
Again it ran great when I test drove it not 6 days ago...so this came on only after I put it in my shed.
I had planned on changing the oil anyway, what is in there appears to be something thick...thicker than what I'd expect from the 5w20 ive seen specified for this tractor. Is it possible the cold weather and the wrong oil has made it difficult to turn the engine over? or do I need to be worried about a bad starter or bad solenoid or am I completely missing the boat with this.
Again its a 1950 Massey-Harris Rowcrop tractor, with the 4 cylinder MFB162G Continental engine in it. It has been converted to 12 volt.
Thank you for any thoughts or suggestions. I'd hoped to have this tractor running after the new battery as i need to move some down trees with it.
