power steering cylinder
conglomer
New User
The power steering cylinder was leaking, so I am rebuilding it. The book says there are screw nails in the cylinder body. Can someone tell be how to deal with them? I didn't see a felt washer in the seal kit I got. Might it be ok if I replace all the seals except the ones behind the screw nails? Meanwhile, this project is moving along. New rod and 2 main bearings brought the oil pressure up nicely and the end play down to .012. Water pump. Hoses...
