What should I time cam to? Reading alot on how to degree a cam and was wondering what point should intake valve open? or is there a standard or is it an every engine is different deal?
what is the best way on a 2 cylinder to find tdc with engine assembled, a bolt into a spark plug hole or just take head off and install piston stop that way? Doesnt make a whole lot of difference to me, if I can do it with engine assembled that would be great.
Is there much advantage to scavenging on these low rpm engines or can it actually hurt? Has anyone tried running different ratio rockers on intake and exhaust?
On a leak down test how many psi drop over what amount of time would be considered normal?
