Farmall B Magneto
Posted by Dave G on February 16, 2001 at 20:02:49 from (158.252.164.227):
I've been messing around with a IH magneto from a B and was wondering how to index the 2 small gears that mate under the rotor. Specifically the small gear and the rotor gear. I can't seem to find any such index to make sure the rotor is lined up with the distributor when it trips. I found one notched tooth on the small drive gear but nothing on the rotor gear. My guess is this notch lines up with the rotor plate notch where the rotor locates. I suppose my explanation is clear as mud. Any help -- thanks.
Post A Followup
: Re: Farmall B Magneto
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
