Removing M clutch shaft?
Posted by Lowell Davis on April 22, 2001 at 11:33:49 from (207.206.16.228):
The Lift-All reservoir on my '46 M was leaking oil, so I took it out to replace the gasket and do a proper job of sealing the fittings. Figured while it was out, I should replace the transmission drive shaft and countershaft oil seals. The drive shaft coupling won't come off because there's not enough clearance to slide it off the shaft until it bumps into the clutch shaft. The reprint service manual I have suggests you can remove the clutch shaft after unbolting the clutch release sleeve carrier. Not in my experience! Now I have the opposite effect - the clutch shaft bumps into the transmission drive shaft coupling before it clears the splines on the flywheel. About the only thing left to do is unbolt the clutch itself from the flywheel. I'm just wondering whether this will do me any good, or if I still won't be able to get the clutch shaft clear of the transmission drive shaft coupling. This is starting to remind me of the bathroom project we did last year. We needed to fix the floor under the toilet, and by the time we we done we had taken the whole room down to the studs.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
