Posted by zooeyhall on March 08, 2009 at 08:48:30 from (98.134.156.92):
I had to completely dissassemble the Lift-all pump on my M. I am in the process of putting things back together, and had a question about aligning the pump gears and the pump body. I've used a good micrometer I have the correct shim arrangement giving the recommended side clearance. However there doesn't seem to be anything to ensure the "centering" of the gears in the pump body--no dowell pins or anything on the back plate. When I try to tighten the pump body bolts the gears become hard to turn. Is there some sort of knack to this? Any advice is appreciated!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
