More With H Steering
Posted by 1PWRFULH on July 18, 2001 at 09:47:44 from (63.23.233.150):
For those of you who didnt read my first post I had a really bad problem with the front wheels wobbling on the H in 5th gear. The worm and sector gear doesnt have very much play in it so I jacked the front of the tractor up today and pushed the front wheels back and forth and noticed little movement. What I found was a little different. You probably dont remember but I had a post awhile back about when I had something heavy on the 3 pt and whenever I let the clutch up or hit the slightest hole I would hear a loud BAM BAM coming from the front. Well I noticed that while I was jacking the tractor would go up about a 1/2 inch before the front wheels even thought about going up. I let the jack down and it made the same noise. Jacked it up again to observe more and the whole tractor moves up probably a little more than a 1/2 inch before the front bolster wants to come up. Could it be a bushing or bearing that is bad? Thanks in advance!!! I think I will try to work on it friday.
RC
Post A Followup
: Re: More With H Steering
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
