Farmall Tractors Discussion Board
PTO turns with lever down; and seems to slip
Posted by charles on February 25, 1999 at 17:38:17:
I've got a IH 340 Utility with an independend PTO controlled by a level on the right near the fender.
To engage it, you lift it up and its got a little lock. Two problems: 1. When in the "off" (down) position it really doesn't stop turning any more - which makes putting on the shaft really hard since I have to cut the engine off and the hitch drops to the ground. 2. When I bush hog it cuts OK if the grass (or brush) is short but if I put a load on it (higher grass) it seems to slip and just stop turning - so I have to make several passes cutting just a little each time. Really slows things down.
Suggestions?
Post a Followup
: Re: PTO turns with lever down; and seems to slip
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
