Farmall B - a real stumper
Posted by DAve G on September 22, 2001 at 17:59:59 from (158.252.164.152):
Well- I spent all day at my neighbors trying to fix his Farmall B and I thought it would be easy. It starts and runs fine for about 5-10 minutes then sputters and will kill unless the throttle is rolled back. Choking it seems to help keep it running also. If it sits a few minutes it will run fine again for about 5 min. Here is what we did and still no better:
switched carburators
checked the gas lines and gas flows fine
new points, condenser, coil, plugs
Baffled - could it be the valves or intake manifold that acts up when hot?
Thanks anyone
Post A Followup
: Re: Farmall B - a real stumper
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
