IH 1206 Rear Seal
Posted by ihdoug on October 18, 2001 at 07:50:15 from (207.230.218.32):
Any advice on replacing Rear Crank seal on DT361? I just replaced it last week when I replaced the clutch, and I see that the bottom of the bellhousing is wet with engine oil. When I replaced it, I removed the Seal retainer ring and popped the seal out. Then I carfully removed the wear sleeve from the crank hub. after cleaning the parts off, I replaced the retainer, applying sealer to the backside, and centering the retainer around the crank hub with a micrometer. Then I pressed the seal and sleve as a unit on the crank, using a steel plate and bolts into the crank until the wear sleve sat flush with the back of the crank, and the seal was centered on the sleeve. I made sure to add sealant to the i.d. of the sleeve and o.d. of the seal. Everything was kept clean, and square. But it still leaks. Any advice? I posted this message a few days ago, but can't seem to find it.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
