Farmall Tractors Discussion Board
Would the C123 motor enable me to use the 2 bottom plow w/ Super A?
Posted by Daniel on March 07, 1999 at 14:26:59:
Based on response to an earlier post, I belive my 1951 Super A has the C123 motor. The casting numbers are correct for the C123 and the date code is from 1951. Would this larger motor enable the Super A to more easily handle the two bottom plow? Acording to the descriptions from my last post, the plow I found is a two bottom IH plow for a Super A. Thanks, Daniel.
Post a Followup
: Re: Would the C123 motor enable me to use the 2 bottom plow w/ Super A?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
