DAN DOYLE said: (quoted from post at 20:46:27 03/15/09) i have a freind that is the shop teacher in the local high school and has the hot tank and valve grinder do you think we can tackle it or is it a job for a pro he can do car/truck heads never any thing this old
No more complexity than newer ones, but likely a bit bigger and probably heavier too. Also, did you plan on magnafluxing it? Milling? Seat inserts? Not endorsing either route, just noting parts of the equation that you may or may not have in mind for the head job, and he may or may not have the equipment for.
As far as costs, if you ballpark $200 in labor with potentially double that in parts (or very little if the guides aren't shot and the valves are good enough to grind), you can weigh your options.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
