Farmall Tractors Discussion Board
1964 cub trany wine
Posted by Walter on March 12, 1999 at 10:16:05:
I recently rebuilt the trany in my '64 cub. Because of excessive gear wear from clutch problems over the years I had to replace 6 of the 7 gears inside, now I have a loud wine in reverse and second, before the rebuild it had a wine in first and third. The wine is so loud you can bearly hear the tractor running. Should I be concerned or is this just due to the fact that the gears are new and have not hade enough hours on them to wear them in. Also replaced all bearings throughout the trany & differential.
P.S. Gear lube is 80-90
Any suggestions would be appreciated.
Walter in lower Michigan
Post a Followup
: Re: 1964 cub trany wine
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
