Farmall Tractors Discussion Board
340 steering wheel
Posted by JohnH on March 23, 1999 at 15:48:24:
I have a 340 Farmall I'm trying to replace two sleeve bushings that are on the shaft the steering wheel is on. I put a gear puller on wheel after removing the nut, it does not want budge. I'm I missing some thing that needs to also need to be done, or maybe I need to heat wheel with tourch then use gear puller. Any suggestions would be greatly appricated.
Post a Followup
: Re: 340 steering wheel
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
