Farmall Tractors Discussion Board
51 Farmall H Update and website update
Posted by The Red, John Fritz on April 05, 1999 at 07:54:16:
The Finale page is updated on my site. The tinwork is now painted along with the seat parts. I got a new spring and shock absorber and another used seat bracket that was hardly weathered at all. I will probably replace the tin down the road.
I have the light shells mounted and HOPEFULLY I have a good ground on each one. I did some carefull filing this time around to make sure I have a ground from the light base to the deck.
I have to work on the oil pressure guage line. It is leaking at the base next to the oil filter. Might have to get another line.
I drained the liftall yesterday. Good news, clean oil. Bad news, only 1/2 quart came out. Since it was hooked up, I bet I have damage to the pump.
I will pull the rocker arm assembly tonight and re-torque the head bolts. I will of course re-check valve gap clearances when I re-install the rocker arms.
At hour 10 I will change oil, filter, drain the water and add anti-freeze and prob. replace the water jacket inspection plate with one that is not as pitted. I will also drop the oil pan and apply red silicone sealer to the pan and gasket.
At the end of this week I will add the decals.
I have spent 40 hours over the last 4 days and I am tired. I came to work to rest. :)
Post a Followup
: Re: 51 Farmall H Update and website update
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
