Farmall Tractors Discussion Board
IH 350 Gas Utility Needs help, owner is stupid
Posted by W. Blue on April 25, 1999 at 00:09:00:
I have a 350 utility gas that was running fine and started to sputter. I shut it off. It would not start and after several attempts I burned out an already worn armeture in the starter. I had to move the tractor so I pulled it started and it started and ran fine, so I parked it. Replaced the starter and the new one locked up when I tried starting the tractor, so much so that I had to pry it loose with a bar. Now here is the stupid part. I tried to pull start it again and this time noticed a clunking and the sound of what I think was parts breaking in the area of where the tractor splits. I immediatly stopped the pulling and then noticed smoke pouring from the area of where the tractor splits or the ring gear area. Now my questions. What would have caused the tractor to sputter and not start the first time, or what would have caused the sound of or the actual breaking of parts in the tranny. What would have caused the starter so much stress as to not be able to turn over the motor. How do I check to see if the motor is frozen or if the tranny is truly all busted up without spliting the tractor in two. Can anyone offer advice or any suggestions on what happened or how to fix it. Thanks, Bill
Post a Followup
: Re: IH 350 Gas Utility Needs help, owner is stupid
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
