Farmall Tractors Discussion Board
Diesel Fuel Leak at Pump
Posted by TMAC on April 29, 1999 at 19:05:33:
With the oilpan off of a SuperMD, I am getting 2-to-3 drops per minute of fuel from the front pump side of the block. I'm guessing its coming from the fuel pump gearing. I am going to remove and clean the check valves of the plunger and the scavenger return. Is there anything else I should check?
Post a Followup
: Re: Diesel Fuel Leak at Pump
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
