Re: A-Running better, but losing power under load
Posted by Roger Mills on April 07, 2007 at 08:02:40 from (71.213.65.16):
In Reply to: A-Running better, but losing power under load posted by kazenza on April 06, 2007 at 12:22:14:
If you have the old carb and mag-try swapping them back in one at a time to see if either helps. A new mag can have a bad condenser as many are bad from new. A new carb can have sticking floats as thay are not run tested. A new carb on an old fuel system can get plugged immediately so check it. Check to make sure the manifold is seated and not leaky. Unlit propane torch at the intakes will tell you.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
