Farmall Tractors Discussion Board
Quick update
Posted by Milan D. Radakovic on April 30, 1999 at 17:36:12:
I adjusted the valves today with advice from The Red, I had conflicting info from two different manuals. Went to the IH dealer today, ordered new seals and gaskets for the steering worm wheel and shaft assembly. I took the governor with me for them to inspect, I was having trouble with low idle, it checked out o.k., guess I just need to fine tune the carb and linkage. The valves also could have been out of adjustment, I didn't check it before disassembly. Time to head to work, see you guys tomarrow.
Post a Followup
: Re: Quick update
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
