Re: Speedy help needed for 1957 IH 350 hydraulics
Posted by the tractor vet on May 02, 2007 at 16:55:32 from (76.212.224.60):
In Reply to: Speedy help needed for 1957 IH 350 hydraulics posted by Joe Sylwestrzak on May 02, 2007 at 16:37:19:
Well if the engine runs ya can rule out a sheared key on the pump. And if it has fluid then thats out . Now if it is air locked then you will have to bleed the air out of the pump and on top of the pump is a allen headed plug remove the plug and crank the engine over , i like doing this with the coil wire off and with the plugs out as i realy hate cleaning up the mess . Next would be checking for a stuck pressure releif valve or a pluged screen . Ya need a book to see what all needs to be checked.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
