Farmall Tractors Discussion Board
derned steering column
Posted by AL on May 07, 1999 at 15:12:45:
I am having trouble removing the steering column from my H. I have loosened the bolts at the u joint but the two shafts will not separate. Do I use a big sledge hammer? CUT IT WITH A TORCH? It is probably an easy job but I am not seeing the solution. thanks for any help.
Post a Followup
: Re: derned steering column
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
