Re: run on
Posted by Mark Ollila on June 11, 2007 at 22:03:02 from (24.192.130.80):
In Reply to: run on posted by Andy Schuppert on June 11, 2007 at 18:37:08:
Andy, Also, make sure your throttle blade closes properly -- no shaft wear, loose or bent. Even with a good throttle blade, my 1953 Super-M when worked hard, will run-on if I don't let it cool down for about 2 minutes. I've set the low-idle speed to about 425 RPM and made sure the spark timing (battery ignition) is correct for an engine with fire-crater pistons. While applying the choke and engaging the clutch in gear does stop the engine from running on, I'm not a big fan of doing this. The first washes down cylinder bores with unburned fuel and the latter stops piston movement during an uncontrolled combustion event -- both are hard on an engine. Hope this helps. Mark
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
