Farmall 560 Hitch
Posted by Fredd on June 20, 2007 at 11:17:24 from (208.103.143.7):
I bought a late model 560 last year and got her running pretty good over the winter. This spring I started pulling hay wagons and such and it worked fine. Last week I was baling with a 966 when the clutch went out so I finished baling with the 560. When I hooked the baler on the drawbar which is in the quickhitch it started pulsing like the baler tonge was pushing it down and it would compensate by opening the valve and coming back up. This pulse was about 2 times per second. I experimented a little bit and it seems to do the same with any tonge weight over about 300lbs. Is there an actual drawbar that I am missing or is this hydraulic pulsing normal?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
