Farmall Tractors Discussion Board
Slowly dying Farmall A
Posted by M.H. on May 17, 1999 at 10:48:20:
I recently got a Model A running from a 10 year retirement. It seems the more I run it, the worse it sounds. It started with a nice purr a few months ago. It now has a Blum, Blum, Blum sound. I replaced the plugs, wires, points, and condenser a few months ago. It does not require the choke when starting. (I assume it is getting way too much fuel) I tried to adjust the carburetor, but the screws made no difference. The oil pressure seems to be a tad lower than normal. Do you think that I have a fuel clogging problem? Thanks.
Post a Followup
: Re: Slowly dying Farmall A
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
