Farmall Tractors Discussion Board
Reversing polarity on a 12 volt regulator.
Posted by The Red on May 22, 1999 at 06:00:07 from (216.192.170.58):
I know this subject has been covered a few times. My converted 6 volt to 12 volt generator is now 12 volt negative. What is the trick to reverse the polarity on the regulator? It would be easier just to keep the system positive ground.
If I wake up, I will check the archives.
Post a Followup
: Re: Reversing polarity on a 12 volt regulator.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
