Farmall Tractors Discussion Board
Ground Zero....in the beginning++with pix
Posted by Mike McKay on May 26, 1999 at 20:32:28 from (207.22.129.37):
After months of work I have finally got to a point that I might can start to reassemble something once new seals arrive. This is what remains of my 1947? Super A. I have rebuilt the PTO with a used housing( old one was cracked) and new bearings and seals. Grass in yard is knee deep and this project isn`t anywhere near mowing the lawn. A few pics of some of the parts and will post some more when things look a little more like a tractor. Mike
Post a Followup
: Re: Ground Zero....in the beginning++with pix
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
