Farmall Tractors Discussion Board
Help! H Carb Settings!
Posted by john on June 22, 1999 at 05:55:09 from (198.70.112.100):
I need help regarding initial carb settings on an H. Our H project is nearly complete but the tractor runs terrible despite complete tune up, wires, plugs, points, condenser, rotor, etc. Please begin by describing which screw needs set (lowest one on carb bowl, upper screw on lower half, and the side screw on upper half). Also what is the correct float setting too! Thanks.
Post a Followup
: Re: Help! H Carb Settings!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
