Posted by Janicholson on March 24, 2009 at 06:43:35 from (199.17.6.128):
In Reply to: re: Brownie 450 posted by Shawn in PA on March 23, 2009 at 17:56:07:
Do not worry about excess RPM, it came out of a car with 3 or 4 times the RPM, and alternators like these are self limiting on output amps. The issue is where the amps are going when the ignition is turned on. I would not change anything until a different good amp gauge was installed. Knowing the real numbers is important in this case. The light bulb test you describe is normal, but does not allow a number to be associated with the amount of draw. A good quality Multimeter will have jacks located on the front to allow a 20 amp load to be placed across the leads. The meter is placed between the battery post and removed terminal (as you did the light bulb. Using that, a good amp meter, or a hold against the wire meter (cheap at the auto parts store), Will measure the actual draw (which should be about 3 to 4 amps with the points closed, and near nothing with them open. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
