Farmall Tractors Discussion Board
1944 Farmall H questions. Please Help
Posted by John T on July 15, 1999 at 08:08:00 from (205.183.16.153):
I have a few problems, and questions about my 1944 Farmall H . I started the H for the first time last night. Topped off the antifreeze. Checked the oil with the petcocks on the side of the oil pan. There was a flow out of the lower but not the upper. I can't find where to put the oil in to top it off. There is no cap on top of the valve cover. A service man said there is a port on the right side of the engine block but all I could see was the oil filter casing. Do I top off the oil there by removing the oil filter?
Also I put a brand new battery in the unit, hooked it up negative ground, positive hot. It turned over hard, that is, it didn't always want to turn a full revolution or more to allow the engine to fire and run. I had to press the starter intermittently until it would turn over continuously and fire. It did start right up after a couple of trys. It probably hasn't run in a couple of years. It has been sitting in a barn out of the weather. The gas may not be top notch. The engine misses a little bit.
I ran it for about an hour, it runs a little smoky. Is there a problem there? After I parked it back in the barn I tried to start it again and it didn't want to turn over easy again. I couldn't get it to start again. I didn't want to keep trying because it was getting late and the nut on the back of the starter button was getting hot. I didn't want to burn up the starter either. What do I do about it turning over so hard?
A question on the rotary switch by the amperes gauge, does this indicate that the ignition is turned on or that it is allowing a charge to go from the alternator (or generator) to the battery. Someone mentioned a Lo-charge, Hi-Charge, Off position arrangement, is that how it works?
One more question, on the control plate that has the choke, and pulley controls there is a lever that looks like a crank but the linkage rod goes to a pivot point on a casing forward of the ignition set up. The linkage is a push-pull. This casing has an approx. 2 1/2" cap that unscrews. What is this lever and what is the function of the unit it is attatched to?
Any help I can get would be greatly appreciated. I'm going to buy an owner's manual tomorrow from the service man but I can start thinking about the problem today, and advice from wise and knowledgeable owners is very valuable to me.
Thanks
John :)
Post a Followup
: Re: 1944 Farmall H questions. Please Help
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
