Farmall Tractors Discussion Board
Light switch wiring
Posted by Joe Berendzen on July 27, 1999 at 13:41:11 from (164.89.253.3):
I want to put lights back on my Super M to complete the re-wiring job I've started. I have had the switch box apart and cleaned all of the spiders and wasp nests out and cleaned up the terminals. While I was at it, I tested all of the contacts to find that all worked fine. I believe there are B and D settings on the switch which I took for Bright and Dim. In testing the terminals this seems to work right. However, I saw a post a while back where someone was talking about the switch being for high and low charge control for the generator/battery. The wiring diagram I got from the Case/IH dealer does not go into that level of detail on the light switch. Can someone clarify this for me?
Post a Followup
: Re: Light switch wiring
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
