1946 farmall cub
Posted by Arvil Porter on March 08, 2002 at 21:53:15 from (216.76.248.65):
The tractor stars up fine and Idles , but when you increase the throttle it will run for a few secs. then quit , If you add about 3/4 choke it will run better, If you run the screew all the way in it seems to run a little bit better to try and fix the problum I did a valve job have 75 lbs compression on all clyd,s rings must be worn a little, the timing is corect, installed new points and condencer, rotor rotor cap, cleaned the fuel tank and lines, got good fuel flow to the carb rebuilt the carb , Diden know the flot setting so I left it the same it has a soled needle and seat no sings of whair on eather no sticking eather , no holes in the foat New head gasket new manafold gasket, new coil, recheked the timing , after all this no chang ? used soape to try and see if I had a air leek couldent find eney the tractor Idles good jut wont run long if you give it the throttle Gov seems to be working ok'also, Iam open for just about eney sugestions to get it runing right, Arvil
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
