HEY Steven@ND!!
Posted by Mike ISW on April 04, 2002 at 20:06:09 from (152.163.207.51):
Hi, I am having the same problem,as you mentioned in a earlier post, with my oil pressure gauge. Could you elaborate on how you did it? Fittings used etc.? Pulled the lift-all out of my H tonite to remove the forward bearing assembly from the trans main shaft. This project is a really good example of the "snowball effect". Started to do the brakes and bull pinion shaft seals. Found a bad bearing on right side. Pulled deck and found slop in trans main shaft. Frt bearings bad. tried last night to get forward bearing assembly out without removeing lift-all/not happening!! And I'll be damned if I can find the 3 or 4 missing balls from that bad bearing! Lots of metal from bearing cage but no balls. I even strained the gear lube as I drained. I'll look real close in the forward compartment when I remove the main shaft. Main shaft is going to get all bearings and maybe a fourth/fifth sliding gear. Mike
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
