Farmall Tractors Discussion Board
Model I-574 bogs down.
Posted by Sourdough on August 07, 1999 at 07:51:31 from (209.187.29.3):
Industrial 574 (Ser. No. 2310013U002984*) with IH 1550 loader.
Problem(s)
1. Gas engine bogs down when load is applied(presently using to pull 3 pth 60" finish mower, usually in gear 2 or 3 of lower gear range).
There is no sputtering and no backfiring. Runs smooth in idle and at 2300 rpm prior to letting out clutch. Continues to run smoothly but acts as though there is no power when clutch is let out. Then rpm drops and engine dies. Engine sometimes dies even if clutch is disengaged at 800+ rpm after the bogging down begins.
2. When placed in upper gear range, position of gear selection lever will not change gears(1-4). Tractor moves at same speed in gear positions 1-4,
apparently stuck in 4th gear. Normal operation in lower gear range (all four gears available).
3. When clutch is engaged there is a delay before the tractor starts to move. Sometimes you have to place your toe under the pedal. linkage seems to be OK.
4. Replaced hydralic fluid filter. Replaced the fluid drained to do this. Fluid level measures OK. Now loader raises extremely slowly.
Post a Followup
: Re: Model I-574 bogs down.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
