Farmall Tractors Discussion Board
IGNITION MADNESS
Posted by Tim B on August 09, 1999 at 17:04:12 from (208.192.18.63):
I'm working on a 48 Super A It has a magneto ignition. But the previous owner added a coil and a new ignition switch basically using the points of the mag like those of a regular distributor. This all worked fine until I screwed things up.
I put new points in the mag and in the process I screwed up the mag timing. I have followed the owners manual on retiming the mag but I can't seem to get it right.
I put #1 on TDC, align the rotor with #1 on the dist cap, but lugs on the mag do not align with the slots on the mount. What is wrong?
I managed to get everything aligned buy twisting the lug against the internal spring. Followed the rest of the instructions and still not right.
Post a Followup
: Re: IGNITION MADNESS
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
