300 and 460 PTO interchangeability
Posted by Joe on May 06, 2002 at 20:04:53 from (66.43.207.226):
Do any of you know if a person can put a 460 PTO unit onto a 300, or a 560 unit onto a 400? The 300 and 400 have nasty independent PTO units on them with reactor bands, which are always slipping for me, and I cannot get them adjusted right, they are either too loose and will not continue to drive things, or they are too tight, and turn the PTO when the handle is OFF. The later model 460 and 560 had over-center clutch PTO units, and I was just wondering if the bolt pattern, input shaft, etc, were the same.
Post A Followup
: Re: 300 and 460 PTO interchangeability
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
