Wheel bearings/seals: Can anybody help?
Posted by Bruce on May 18, 2002 at 05:35:21 from (216.179.1.173):
I'm replacing the front steel wheel hubs with round spoke wheels on my F30. I noticed that, even though the bearings are the same, the inside diameter of the round spoke hub is smaller than the steel wheel hub. Both hubs have a "ring" that is pressed into the hub on the inside end. Is this called the felt seal retainer? When taking off the steel wheel hub, I found an oil seal and a felt washer behind it. However, when I put the inner bearing on the axle and tried to put the round spoke hub on the shaft, it wouldn't go on because the seal wouldn't fit in the hub. Since I had a new felt washer and oil seal, I removed the original one (destroying it in the process),and removed the ring (retainer) from inside the hub, which I don't think I should have done. The round spoke wheel is now on, but does not turn freely. THe bearings are not too tight, but I think the drag is caused by the new seal and felt washer, which is turning when the hub turns. Is it supposed to do that? Also, which way does the oil seal go on? I have it with the flat side out and the indented side facing the felt washer. I'm stumped as to how all this is supposed to go together and work. It looks simple enough, but I just don't get it. Any help would be highly appreciated. Pictures too, if possible.My F30 parts manual doesn't give a very clear picture of this.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
