which radiator fan for a B?
Posted by little roy on July 24, 2002 at 18:56:31 from (63.26.128.87):
My grandfather's B is running fine, but I need to replace the fan (it really loses a lot of oil out of the front end) Which is better - the old style with the plug where you squirt oil, or the newer style with the sealed bearing? I don't use it for anything heavy - just drive down the side roads and occassionally pull a hay rack. Thanks.
Post A Followup
: Re: which radiator fan for a B?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
