Draining Battery
Posted by Jeff S on September 28, 2002 at 19:15:26 from (216.109.199.28):
I have a 1946 Farmall H. It has been re-wired using all stock replacement harnesses etc. It is a 6V battery/dist. ignition with a cut-out relay (No voltage regulator). A month or so ago, the lights stopped working. Fuse was bad, I also discovered at the time that the generator field resistance strip was broken. I ordered a NOS 4 pos. light switch (the only way I could find to get the field resistance strip replaced). Before putting the new switch in, I wanted to verify that my wiring job from a few years ago was accurate. Someone forewarded a link to Bob M's diagrams to me (thanks Red!), and I ended up switching one wire. Then the battery started going flat all the time. Last week after fully charging the battery, I mowed for 4 hours, unhooked the posative ground left it unhooked for a week, and it was flat dead today. Could it just be the battery happened to go bad the same time I switched the wire? Could it be the relay points sticking? Does the broken field resistance strip have anything to do with it? I haven't put the new switch in yet. I have been through the wiring comparing it to Bob M's diagram several times and it is wired correctly according to the diagram. HELP!! Thanks, Jeff
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
