Farmall Tractors Discussion Board
Damaged outer spline on differential shaft
Posted by Farmer Bob on August 31, 1999 at 23:04:08 from (207.227.238.112):
Following removal of disk brake assembly on my '48 M to replace bull pinion oil seals, noticed damage to left-inside end of outer spline that fits over differential shaft. Damage is limited to the beveled portion on inside end of outer spline. Bearing appears sound (no rough edges noted) "L250" and "Made in USA" clearly readable on bearing yet I can't determine what would cause the chewing marks on the outer spline. Right side also removed with no damage seen. I have a .jpg of it but can't figure out how to post it here for y'all to view. Any help appreciated.
Post a Followup
: Re: Damaged outer spline on differential shaft
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
