Lifting and Mounting a C113 engine
Posted by David Bean on January 13, 2003 at 09:18:45 from (208.15.63.194):
Hi all,
I'm about to split a 1950 C to remove the engine for an overhaul, but it's the first time I've done it, and I've got a question that maybe someone can help me with.
Where on the engine would you attach the chains for the lift, and what hardware would you use? (I bought the overhaul video and I can see that they used eye bolts, but I couldn't tell where they were attached exactly.) Second, where would I attach bolts to hold the engine on the engine stand, and what size bolts should they be?
I'd like to get whatever hardware I need before I start the process...one trip to the store vs. the five or six that normally happen ;-).
Thanks in advance!
- David
Post A Followup
: Re: Lifting and Mounting a C113 engine
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
