Farmall Tractors Discussion Board
Small gear shift lever on RH side of trans housing
Posted by Jeff Dahlke on September 07, 1999 at 18:56:31 from (12.28.99.15):
I have a 1951 Farmall MD that has a small gear shift lever on the right side of the trans housing. It has M-W Gear CO. Anchor ILL cast into it. I can shift it up and down but it makes no difference in the speed of the main transmission. I know it is not a T/A as this would be a larger lever. Also 1st,2nd & rev. gear speeds are a lot faster than on my other Farmall M. Could someone shed some light as to what this lever would be for? Thanks.
Post a Followup
: Re: Small gear shift lever on RH side of trans housing
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
