Farmall Tractors Discussion Board
oil seal for Farmal M steering column
Posted by Joe Roberts on September 07, 1999 at 19:31:01 from (129.190.153.110):
I am in the process of restoring a 1949 Farmall M. I need to replace the two oil/grease seals that are located in the steering mechanism. One is located in the steering wheel shaft and the other is located in the vertical column. Anyone know of suggested source for such parts?
Thanks, Joe R
Post a Followup
: Re: oil seal for Farmal M steering column
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
