350 voltage
Posted by Dale on March 03, 2003 at 21:07:10 from (12.93.72.225):
My dads 350 is 12 volt - ground with a 6 volt coil it has a resister block before the coil.The problem is it started running bad so I was checking it out and found that it has only 4.35 volts at the coil ,if I jump out the resister it smooths out and runs great should I trash the resister and put a 12 volt coil on it ?????
Post A Followup
: Re: 350 voltage
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
