Farmall Tractors Discussion Board
Cub Electrics
Posted by Chris on September 09, 1999 at 20:59:18 from (216.176.147.40):
I have a Cub with a cutout relay. The battery wire goes into the relay at the BAT terminal and the ignition switch wire runs out from the same terminal to the switch. My question is: Is this setup correct, or should the switch wire run out from the terminal on the other side of the relay coil? Plus, what kind of charge and discharge should I be seeing at idle, loaded, lights on dim, high?
Thanks, Chris
Post a Followup
: Re: Cub Electrics
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
