FARMALL (A) HEADGASKET/ TEMP GAUGE
Posted by J MIRGON on April 17, 2003 at 20:59:12 from (205.208.129.43):
RECENTLY RAN MY (A) FOR THE FIRST TIME AFTER REBUILD, RUNS GREAT, BUT I AM GETTING SOME SEEPAGE OF COOLANT BETWEEN THE HEAD AND THE BLOCK, I RETOURQUED THE AFTER ABOUT AN HOURS RUN TIME, AND THEN TOOK THE HEADBOLTS 10 FT LBS OVER THE RECOMENDED 65 TO STOP THE LEAK BUT THAT DID NOT CURE IT EITHER, ANY SUGGESTIONS ?
PUT A BRAND NEW TEMP GAUGE ON ALSO , HOWEVER THERE IS NO WHERE IN THE RADIATOR OR THE HEAD FOR IT TO THREAD INTO, HAS AFTERMARKET RADIATOR, WHERE DOES IT SCREW IN ?
THANKS FOR YOUR HELP
JONATHAN MIRGON
Post A Followup
: Re: FARMALL (A) HEADGASKET/ TEMP GAUGE
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
