Farmall Tractors Discussion Board
Magneto problems
Posted by Vernon Graham on September 13, 1999 at 23:09:17 from (12.73.96.221):
I have a '53 Super A with magneto ignition. Sometimes after sitting for a month or so it either won't start or will start and then quit after running for a few minutes. (The gas is working ok)
I check for spark and find very weak or no spark.
I remove the magneto, take it apart, put it back together, re-install it and it starts right up.
This is getting old, although I can do all this in about 15 minutes now (practice makes perfect).
I took the mag into my local dealer and they said it was in good condition. Naturally I have replaced the points, condenser, cap and rotor as well as the wires and plugs. I am looking for any help you can give me.
Post a Followup
: Re: Magneto problems
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
