DESPERATE!!! Super C engine problems!! S.O.S.
Posted by Jesse on May 03, 2003 at 18:46:42 from (207.162.163.19):
Here is the problem I am having, I hope that some of you can give me hints as to the source of troubles...I have a 53 Super C that had good oil pressure, etc....I have been using it to pull a few things these last few days, nothing it can't handle. At any rate, I went to start it to pull it to the barn--it normally starts when you hit the starter rod, but tonight it tried to start, then nothing........When I hit the starter again, there was a waft of smoke that looks like it came from either the battery or start switch area. I changed batteries and all I got was a hum. I have a hand crank for my C but I can't get the motor to turn. I checked the oil and the oil ran out of the bottom test cock on the oil pan. No prior indications of problems..ANY SUGGESTIONS ????
Post A Followup
: Re: DESPERATE!!! Super C engine problems!! S.O.S.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
