Ratio between Engine and in-Line PTO shaft.
Posted by Brian on May 22, 2003 at 17:35:48 from (65.49.176.204):
Can someone please tell me this ratio ? It's not obvious to me after quickly going through the service manual. I'm using a mechanical tack hooked up to the pto output to set the idle.
Thanks in advance
Brian
Toronto.
Post A Followup
: Re: Ratio between Engine and in-Line PTO shaft.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
